goldstar
- New Jersey
- Electrical Contractor
While at one of my supply houses the other day I attempted to purchase 1 SINGLE 15 amp, 120V receptacle. Their response was that they no longer stock 15 amp, 120V single receptacles only 20 amp (because the cost is about the same) and that I could use it on 15 amp circuits. Something told me this was incorrect but I was in a hurry and not prepared to argue. After reading table 210.21(B)(3) I believe I'm correct by stating that they are not. Logic tells me that if I run wiring for a circuit rated at 15 amps and install a 20 amp single receptacle, that tells an unsuspecting individual that they can plug in a device requiring a 20 amp circuit which, in all probability will result in an overload. If anyone believes otherwise would you please respond and give your reasoning why.
Thanks,
Phil
Thanks,
Phil
