You are correct, and as a further note, you wouldn't need a two pole breaker since you are using two seperate receptacles.Originally posted by epd807:
The machines pull 14A apiece. I figured if I used a 2 pole breaker, the neutral would only carry the unbalanced portion of the load, so the current would never exceed 20A. Am I correct on this? Thanks.
