Kg808
- California
Hey all!
doing a bid for installing a Cummings single phase 120/240V 20KW back up generator. It’s model number C20 N6
i cannot, for the life of me, find out what size the circuit breaker is for the output on the generator. I can do the obvious division and see what the max output is in relation to its 20kw rating but I would really like to make sure I spec out the right wire size for the OCPD and Load. But there is no place I can find that will tell me what the ratings of this thing are.
I don’t do much work with these generators and I’m hoping someone out there has installed one and can tell me.. or there is a generator guru out there that can confirm my simple math and I’ll just run #2’s and call it a day.
Fyi i even called cummings direct and they responded like a deer in the headlights. They kept telling me that the battery charger needed a 120v circuit...? I eventually hung up.
Thanks!
Thanks!
