iwirehouses
A Customer is dead set on buying a generator that comes with a 200 transfer switch. His service is 100 amps. I tried to see if they sell 100 breakers so I could just swap the breakers. But I believe the breakers are physically different.
It’s an older service with the service disconnect/main breaker inside in the panel. What I propose is to just add a simple 100 amp service disconnect outside between meter and new 200 amp transfer switch. Separate the grounds in the neutrals inside. And run the grounding electrodes into the service disconnect outside. Am i missing something? I think this is a simple solution, that way he can buy and use what he wants. And he will have a big generator on a little house
