Benman here.Thanks guys for all the info on the 200 amp disconnect.I'm going to add a little more info.The service is residential,and the service entrance conductors will be ran through a crawl space in 2" pvc from the meter to my 200 amp panel located about 50' feet away.If I put a disconnect under the meter that should take care of the "nearest the point of entry"rule,and also protect the conductors ran inside the house.
