J James Curland Member Oct 22, 2008 #1 For the referenced section of the 2000 NEC Code (680.51(B)), was the max voltage to operate a submersible pump 300 volts as it is in the current code, or was a higher voltage specified? Thanks for the help.
raider1 Senior Member Staff member Location Logan, Utah Oct 22, 2008 #2 Welcome to the forum. First off there is no 2000 NEC. I looked in the 1999 NEC in section 680-51(b) and the maximum operating voltage between conductors for submersible pumps is 300 volts. Hope this helps, Chris
