jahilliard
Could you guys give some examples and a little better description of 406.3(D)3(c)? 2008 NEC. Just making sure I understand it correctly. Thanks
406.3(D)(3)(c) A non?grounding-type receptacle(s) shall be permitted
to be replaced with a grounding-type receptacle(s)
where supplied through a ground-fault circuit interrupter.
Grounding-type receptacles supplied through the groundfault
circuit interrupter shall be marked ?GFCI Protected?
and ?No Equipment Ground.? An equipment grounding
conductor shall not be connected between the groundingtype
receptacles.
