200.2(B) Continuity. . The continuity of a grounded conductor shall not depend on a connection to a metallic enclosure, raceway, or cable armour.
Stallcup?s Code Changes page 2-2, in the Author?s Comment blue lettering area, it says, ?A busbar or conductor must be used to make the connection between the neutral bar and the equipment ground bar, not the metal of the enclosure.?
Do you agree with that conclusion ?
The obvious conclusion is:
200.2(B), any panel that has neutrals on more than one bar can not depend the enclosure to bond them together. . As in neutral to neutral.
But does this also apply to the grounded conductor connection to grounding ? . And if you do agree with Stallcup, do you also agree with Stallcup?s use of the word ?equipment? ?
Doesn?t the grounded wire get its ground path from the electrode conductor ? . How does the equipment ground effect the function of the grounded conductor ?
David
David
