Guys,
Appreciate your expertise on this problem.
Have this 200A main breaker with ten(10)-50A branch breakers that serve split type aircon units. This breaker always trips when 80% loaded.When i checked the voltage rating of breaker, i found out that its rated 115/230 v which i believe would not fit to our system of 1ph,230 volts ungrounded service.I guess had the breaker been rated 230v or 230/480v there would be no problem like this.
Kindly see if im right with this view.
thanks
Danilo
thanks
Danilo
