1.I have a 225a breaker feeding a large condenser unit. Near the Unit there is a 200a non fused disconnect for servicing. Should the disonnect be larger or is the 200a disconnect suffcient for service disconnect at unit?
2. The feeder to Unit is damaged and needs new feeder run. The Location is an old parking garage at apartment complex. The feeder leads into a mech room that feeds another gutter where all the controls are located and then from that gutter feeds over to Condenser Units. I would like to run a new feeder to Unit first and use the undamaged or existing going back to Mech room to feed the equipment for the condenser units. My question to this problem Can I TAP off feeder to feed the equipment and controllers in mechanical room. Using the 10' tap rule i can install a fused disconnect then run existing undamaged feeder back to mechanical room. The distance between the Condesners and the mechanical room is about 100' inside mechanical room also located in parking garage. ALSO if I am able to TAP into the feeder. do i need a OCPD to condenser units from the point where i seperate the feeder one side condenser units and other controllers. Is there anything I should be concerned when deciding to do this? The feeder is damaged and because it ran underground inside parking garage we cant follow same feeder path. We basically need to take the conduit a little longer distance around for clearance.
