LarryFine
- Henrico County, VA
- Electrical Contractor
Hey. Need to price running a 200a 3ph circuit to a printing machine. Run is from an existing 3p fused switch about 5' AFF, up to an 18-20' high bar-joist ceiling, about 60' perpendicular to the joists, and down to another fused switch (came with the machine.)
The wire of choice would be 3x 3/0 cu + ground, of course. Would you choose MC cable or run EMT and pull wire? Should I consider aluminum instead? If so, what size would I need ? (NEC not available right now - long story) Is MC available that big?
It seems the MC would make for a quicker and easier install, and I'm thinking of a strut pole beam-clamped in the ceiling and shot into the concrete floor. Any alternate suggestions more than welcome (as if I could stop you. :grin Thanx as always!
