tim89s
- Brush Prairie WA
Why can you use 3/0 cu for a 4 wire 200 amp panel, 3 phase commercial install? One answer I got was "There is something in the code that states you dont have to derate feeders". Another answer was "I have always used 3/0 for a 200 amp panel." Is it because you derate the 3/0 using the 90 degree table, which is 180 amps after derate. Then you step up to the next highest standard overcurrent proctection which is 200 amps? Please help me to understand this a little better.
Thank you
Tim
Thank you
Tim
