rodroche
 - Greeley, Colorado
I need some advise on an inspector's question on grounding/bonding of metallic water piping systems.  The plumber used both stainless steel and copper piping for the domestic water system.  He installed dielectric fittings between the two types of pipe.  Now there is an electrical question about how to meet 250.104, as now the copper sections are isolated from the stainless steel.  The 6" main is stainless, then changes to steel as it exits the building (underground).  Installing a bonding jumper across the dielectric fittings seems to defeat the purpose of the dielectric fitting.  Should I bond all the isolated copper sections together and then use and bond there to the main line?  Any help would be appreciated.
