Brian Baker
- Basye VA
why would i have 70v line to neutral and 114v line to ground, but other phases equal around 114v line to ground and line to neutral?
That alone does not seem to explain both the low voltage to neutral from one phase and normal voltage to neutral from other phases.Because you have a poor neutral connection.
What are the phase to phase voltages?
This:What are the phase to phase voltages?
line to line I have 204,204,206.
12-15 volts neutral to ground is pretty high, I'm still in the bad neutral somewhere camp. N-G should be negligible with no load, and probably only be maybe five or six volts maximum heavily loaded, unless you have really long undersized conductors.voltage to ground on neutral 12-15v and checking all lines to the same shared neutral just one has 70v reading. .I cant uderstand this when I have 114 to ground on same line. Is something canceling out or something wrong.
THanks to all who comment
