The main purpose of stepping up the voltage is due to voltage drop issues. The feeder run is approximately 6000 feet.
On the distribution location, the voltage will be stepped down again to 208V. Most of the loads are only lighting and receptacles.
Do I need to provide ground with the 4160V secondary delta to the transformer enclosure (through corner grounding) ? Or I can run my secondary as ungrounded system up to the downstream 4160V/208V step down transformer ?
