208V Incoming Power to 240VAC, 60A Machine
I have 208V in the building and need to set up a machine (Single Phase) that has incoming power needs of 240VAC, 60A. I believe that I will need a transformer for this and would like some help figuring out what kind. Please assist. Thanks
augie47
Tennessee
does the machine require 1 phase 240 or 240/120 (is a neutral involved) ?
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
Not sure what you mean by what kind of transformer. Since you have 60 amps you need about a 15kva transformer. 60 * 240v = 14,400 or 14.4kva
Saturn_Europa
Fishing Industry
Electrician Limited License NC
What type of machine is it?
Many motors are dual voltage rated.
Do you have a picture of the name plate?
augie47
Tennessee
:) You have opened pandora's box releasing the bloviators,,, I would suggest you check the link provided or any transformer supplier for "buck n boost" and get the info you desire straight from the horses mouth
(I believe you will end up with a 2kva bnb)
iwire
Massachusetts
But does the kVA still have to meet the same 240V x 60A = 14,400 kVA calculations or can you use a lower kVA?
Much much lower, that is why I use the online or catalog sizing resources.
Using buck boost also simplifies the installation as you will not need a grounding electrode run to it as you would with a standard 208 to 240 transformer.
Jraef
Moderator, OTD
Electrical Engineer
Before spending time and money needlessly, I would do a deep-dive investigation of the machine to determine if the 240V is as critical as you think it is. A LOT of single phase 240V motors are perfectly fine with 208V, because the motor mfrs KNOW that a lot of commercial applications fed from 3 phase systems will be 208V, not 240V. Most electronic power supplies for computerized systems or solid state controls now have very wide input voltage tolerances, for example 110-250V input with no external transformer required. And if it is something like a resistive heating element, the 208V may mean it will not get as hot, but that may only mean whatever it does will just take a few seconds longer. Bottom line, 208V may not be a problem you need to fix.
ActionDave
Chief Moderator
Durango, CO, 10 h 20 min from the winged horses.
Licensed Electrician
Before spending time and money needlessly, I would do a deep-dive investigation of the machine to determine if the 240V is as critical as you think it is. A LOT of single phase 240V motors are perfectly fine with 208V, because the motor mfrs KNOW that a lot of commercial applications fed from 3 phase systems will be 208V, not 240V. Most electronic power supplies for computerized systems or solid state controls now have very wide input voltage tolerances..
I agree.
kwired
Electron manager
NE Nebraska
I also agree with making sure your equipment can operate directly from 208 volts. Many motors will be fine. Heating elements - just don't get quite as hot, but unless that impacts overall performance often isn't a big deal.
If you do need to boost voltage - your kVA rating of a buck/boost is only on the difference between the two voltages.
If you actually have a 60 amp load @ 240 volts then as mentioned it is 14400 VA. An isolation transformer would need to have at least 14400 VA rating. But if boosting from 208 to 240 (a difference of 32 volts), your buck boost transformer only needs a 32 volt x 60 amp = 1920 VA rating.
If you equipment requires a 60 amp circuit - the actual load is likely less and you may even be able to go with a smaller transformer.
iwire
Massachusetts
It is worth a check but for whatever reason I run into and it comes up on this forum that some manufactures get real particular about the supply voltage.
I have had 7-11 Slush drink machines that had very tight voltage specs and threats of taking my first born if the requirements where not met.
People are always asking about this issue with tanning beds, they seem to require specific supply voltages.
Most common for me is motors, specifically refrigeration compressor motors on tractor trailer units. If we run them on 208 they will often trip out the overload, apparently in shipping yards they use 230 delta to supply these units but when they show up at the stores we work at we have 208 available .
Besides that, in the end I make my living installing electrical equipment, talking someone out of a buck boost is counter productive. :cool:
kwired
Electron manager
NE Nebraska
I haven't run into much equipment that can't run on 208 vs 240 or vice versa. Most of the time the issue from the dealer/vendor of such equipment is they will not honor warranty if not supplied with the voltage they ask for. There is a lot of equipment that is marked to operate at either voltage. Occasionally you may need to change a tap on a control transformer or something of that nature, to install it correctly. I have seen many HVAC units installed on 208 systems with control transformer tap on the factory 240 setting that run fine for years.
augie47
Tennessee
There, problem is solved ! Pay no attention to the voltage and in the event something goes wrong tell the customer kwired advised it would be o.k. and send an associated repair bills to him :D
