Toasted922
- Boston
- Journeyman Electrician
Hey guys, so I have an odd issue. I have 208v single phase feeding a pole vac at a car wash. I was called out to get the vac up and running again. The feed comes through a 2” underground pvc conduit along with 5 other vac feeds and 1 lighting circuit shared between the 5 lights atop each vac. The first pull point after exiting the building is a handhole adjacent the pole vacs. In the handhole each leg reads normal for this circuit, 120v to ground with each leg and 208v between each leg, black and red. From there it dumps into a 3/4” pvc conduit exiting the handhole and goes directly to the inaccessible base of the pole vac and then up to a bell box for a service switch. After taking the switch apart to eliminate any kind of backfeed from the motor and/or the wiring the maintenance guys did, I tested at the pole vac to find 0 volts on the black and somehow 208 volts on the red conductor. The service to the building is 3 phase, 277/480v with a transformer inside giving us the 208 three phase. No bastard leg and the service is newly installed, hardly a year old. How is that possible to get 208v on a single conductor with no bastard leg and nothing else hooked up to the circuit to backfeed or interfere? The 3/4” pvc is filled to the brim with water as the maintenance fellas forgot to cap the vac pole, so theres ice given its been 20°F. My assessment was rip out the vac, pull new wires, put the vac back gingerly without damaging the conductors.
