?Make it 3.
N bot floating and c phase is not loosely gndedNeutral floating, C phase loosely grounded.
Bonded to gnd at trans? It is. C phase seems to be wired properlyLike Gar said, neutral not bonded to ground, C phase faulted to ground.
Are you positive? The only way you can get the voltages you posted is a floating neutral. The C phase can be faulted to ground anywhere from the output, to a load faulted. Turn off all loads and see if the voltage changes.C is not grounded and neutral is bonded to gnd at Trans
I will try that again tomorrow. Thanks for the inputAre you positive? The only way you can get the voltages you posted is a floating neutral. The C phase can be faulted to ground anywhere from the output, to a load faulted. Turn off all loads and see if the voltage changes.
It may be a bad connection on the bond between XO and ground, could be burnt from the fault on C phase.I will try that again tomorrow. Thanks for the input
Im still learning . b to e is e earth?Here are.my readings at the 120v/208 panel
an 120v
bn 120v
cn 120v
ab 208v
ac 208v
bc 208v
ag 202v
be 203v
cg 008v
ng 120v
What could be causing this. Defective trans former? Looks like its wired properly
Probably a typo.Im still learning . b to e is e earth?
I agree with the first 2, so make make it 3.
Then explain the voltage readings.C is not grounded and neutral is bonded to gnd at Trans
