20A FSU
rbmcleod
New member
The fuse in my FSU at the furnace blew. I found in the furnace installation manual that it should have been a 20A fuse. The FSU is a typical unit with switch and screw in fuse. Although it will accept a larger fuse, the unit is only rated at 15A. I cannot find a version that will fit in the same single gang box that is 20A. Is anyone aware of one?
Thanks,
Ron
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
