20A minimum CB
lizzie14
I heard that somewhere in the code the minimum cb size you can use is a 20A. Does anyone know if this is for strictly commercial or residential?? Does anyone know where it states that?
Re: 20A minimum CB
I posted this in the wrong section. Sorry. I see that I can't move it though. It should be in NEC.
Re: 20A minimum CB
You can use a micro amp circuit breaker if you so desired to spend the money to have one made. The NEC does not have a minimum OCPD requirement.
Roger
