600 volts between conductors:
So does this mean paking lot fixtures mounted under 22' cannot be provided as 480V-1ph fixtures? that makes it tough on projects where the local ordance restricts your height and you have a large site. is this correct??
circuits exceeding 277 volts, nominal, to ground and not exceeding 600 volts, nominal, between conductors shall be permitted to supply the following.
(1) the auziliary equipment of electric-discharge lamps mounted in permanently installed luminaires where the luminaires are mounted in accordance with one of the following:
(1)(b) not less than a height of 6.7m (22ft) on poles or similar structures.
