RD35
- Bloomington, Indiana
New shop building next to existing home. New feeder from panel at existing home to new panel in new building. Easy enough so far right? So, I also need to run a 12/3 W/G out to the new building to operate lights at the building switchable from both the new building and the existing house via 3-way switches.
Question #1: Is this compliant with 225.30 paragraph #2?
I will also be installing two sets of feeders from the new building to the existing home for standby generator power. One feeder circuit will feed power to an automatic transfer switch for a padmounted generator at the building. The other feeder will connect to a manual transfer switch so that a portable generator can be connected at the new shop building in the event the pad-mounted generator fails. (Actually, the pad mount generator is not in the budget yet, but homeowner already has the manual switches and portable generator...and wants to keep them for back-up...of the back-up!)
Question #2: Is there a violation of 225.30 in this instance?
When the building feeder enters the new building, its first stopping point will be an automatic transfer switch that is equipped with a small accessory handle which can be used to manually move the switch from utility to generator.
Question #3: Would this suffice as an acceptable means of disconnect for the feeder entry to satisfy 225.31? (otherwise will need to purchase a more expensive service entrance rated switch with utility circuit breaker disconnect)
