225 Cut Out Panel
Douglas Medellin
New member
hawaii
Installing a PV system where the engineered plans calls for a 225a cut out panel that's fed from the meter and has a 200a breaker feeding the house 200a panel and a 60a breaker from the PV (panels to inverter to disconnect to 60a breaker in 125 sub panel to 60a breaker in C/O panel) . Problem I'm having is sourcing a 200a breaker in C/O panel that can accommodate 3/0 wire. Sourced a Siemens Q2200BH 200a 4 pole 120/240 v 22k type QPPH breaker but can't determine what load center panel to use. It would also need to hold a 60a breaker from PV.
