I am in the process of installing several new process lines and corresponding MCC's with 24vdc plc control circuits. My company built the cabinets and used blue wire as the +24v line and white/blue as the 24v common wire. Electricians that build 100's of UL listed control cabinets are doing the electric work for us and they say white/blue is not legal as per the NEC and it should be a blue/white wire. In fact, they've never seen control circuits with white/blue wires. I inspected existing cabinets from other manufactures and they also use the blue/white and not the white/blue wire.
To verify which is correct, I searched the NEC and it clearly states 24v dc grounded conductors are to use the white/blue color code. I need to know which is correct. If we're wrong, we need to change our wiring practices.
