Re: 24 vdc relay on 24 vac
By Matt: Edit: Sorry Frank, you're guys' user names look similar. (I had Frank's name originally)
you could still build a small rectifier (single inline case full-wave), voltage regulator (24v) and filter circuit for under 2 bucks if you really had to use that relay. All those parts including a small wirewrap board can be purchased from a local electronics warehouse, or if you must, a local Ripoff Shack, I mean Radio Shack should have all those parts in stock.
I'm not so sure about under two bucks. Most of the consumer type electronics joints I know of everything is packaged for $2.50 and up.
You can build a minimal regulated supply with only three parts and it'll work just fine, for a lot of things.
The trouble is though that semiconductors and inductive loads really don't get along very well. The back emf you get when you disengage an inductive load is bad news for transistor type stuff. They hate backwards voltage. That being the case, if you want to drive a relay with a regulator you'll want to take some steps to protect the thing. So much for the three component regulated supply.
But it's not that bad either. A few capacitors and a diode and it it'll have a good chance of working forever.
The most important thing if you're driving a coil directly with a semiconductor is a clamping diode. It goes across the output reverse biased. The supply doesn't see it but when the coil starts spitting backwards emf into the supply the diode is forward biased and the back emf is shorted to ground. The diode really doesn't care because for it it's forward current.
You'll also want some small value capacitors to shunt the higher frequency garbage the coil's gonna make, the diode's a little slow and doesn't get everything.
[ July 25, 2005, 06:17 PM: Message edited by: physis ]
