I know that #18 THHN, 600 volt wiring used for 24 volt AC can be run in the same conduit as #12 THHN, 600 volt wiring used for 120 volts but I have always been reluctant to do so.
I have four baseball batting cages that will use 120 volts AC for operating the motors of the throwing arms. There is a 24 volt AC circuit that is being used as a switch leg that will turn on the batting cage motor (at the batting cage control box) whenever a coin is deposited (at the coin box) to start the system. Because of the appearance and limited space of :angel:multiple conduits I would like to run the 24 V and 120 V in the same conduit. I hope someone says go ahead but I have never mixed voltages and it is hard for me to do so.
Thanks for any help, it is hard to teach an old dog new tricks.
