24 Volt AC pump
https://www.amazon.com/AQUATEC-Boost.../dp/B012HT1X6Q
Does a booster pump count?
For that matter, a pump is just a pump and can be powered from anything. Get a pump that meets your needs and power it with a suitable 24 VAC (or universal AC/DC) motor.
Now is probably where you tell us why that won't work with info that
I reinserted the comment you removed....
Actually, now I go on Amazon, and order the pump. I wish it had pipe fittings, rather than disconnect fittings, but I'll make it work. Thank you,
You already have it, so this is too late. However, how about putting a diode bridge between the AC output and the DC motor? Should work fine up to 20A range.
Heatsink might get a bit cumbersome in the 100A range.
