bryce_wynia
- Kansas City
- EV Designer
I have a rare case here of a 1600A 208V Main gear where I need to feed a 500kVA step-up to feed 400kw of load of 480V equipment. In this case could i use the Main breaker as my OCPD for the primary side of the transformer (utilizing this tap rule) or would the transformer require its own OCPD ? (The distribution is a 4kV system that will not allow a 480v service voltage, hence the need for this backwards install.
