In light of the other thread that just popped up discussing transformers I thought I'd put this out there for discussion as well because I have seen interpretations both ways.
Do you consider PV an industrial installation as it pertains to 240.21(C)? Is there any overarching definition I am missing, not specifically designated to another section of the code (for instance 240.2 specifically states its applicable to Part VII meaning it is not applicable to other parts) that would preclude this? Power generation is considered an industrial application, and (C)(3) does not refer to the facility itself (whereas again 240.2 specifically does), just "the installation", so presuming there are no loads on the transformer other than power generation and station service associated with that power generation, would you, or would you not allow those conductors to be 25' presuming you also meet the 4 conditions outlined. Notwithstanding art 408, and protection of the panelboard itself, this also allows the conductor to be protected by the sum of the breakers in an MLO vs a single OCPD.
