- Massachusetts
Can we feed a 30 amp 240 volt dryer from two plug type fuses.
Here is the relevant code section, what I do not understand is if we need to meet both requirements of 1 and 2 or do we only have to meet 1 or 2.
Thanks, Bob240.50 General.
(A) Maximum Voltage. Plug fuses shall be permitted to be used in the following circuits:
(1)Circuits not exceeding 125 volts between conductors
(2)Circuits supplied by a system having a grounded neutral where the line-to-neutral voltage does not exceed 150 volts
