I am looking at installing a PV system onto a 240 Delta High-Leg (center ground) service. I have found a single phase inverter that can be connected to two of three phases with this type of service and I'm planning on using three inverters to do a balanced backfeed. I need to calculate out my max line currents to size the equipment between the inverter combiner panel and the utility tie-in.
Are all three phases for this type of service 120 degrees out of phase, similar to a 208/120 or 480/277 where my max line currents would be the inverter current multiplied by the square root of three? This was my assumption until I started googleing the subject and read somewhere that the two "bottom" legs that have the neutral center grounded are 120 degrees out of phase similar to a 240 split phase.
Can anyone clarify on the phase angles measured between L1 & L2, L2 & L3, and L1 & L3? And how to calc out the max line currents when I have three single phase inverters tied to this service in a delta formation? Note this type of tie-in requires the inverter to operate WITHOUT the neutral, which is an acceptable application for the inverter according to the manufacturer.
