hardworkingstiff
- Wilmington, NC
Forget about the heater or any load. You can not connect a 120/240 volt rated breaker to a buss that has a voltage greater than 120 volts to ground.
Does anyone know why? I wonder if the 2-pole 120/240-volt breaker is made with the same parts as the 3-pole 240-volt breaker?
Is it really a breaker issue or is it just a way to not allow a non 3-phase load to be connected to the "wild leg"?
