Jason Spray
- Phoenix, AZ USA
Can you utilize the high leg of a 240V 3P 4W Delta system as one of the 2 hot legs for a 240v single phase piece of equipment?
Yes.Can you utilize the high leg of a 240V 3P 4W Delta system as one of the 2 hot legs for a 240v single phase piece of equipment?
Yes, but one must be careful if there is a neutral and any 120V loads in the equipment.
You will get smoke if the 120V part gets the high leg.
Usually there is no neutral in 240 3P delta system right ?
从我的 iPhone 发送,使用 Tapatalk
Not only can you, but most of the time, you should include the high leg in your 240V 2-pole loads. This helps balance the panel in most cases.
Not necessarily. In many high leg services the high leg has much less capacity than the other two and the POCO does not want you to balance the load over all three phases. We sometimes encounter this when we are designing a PV system; many times the POCO wants us to interconnect only on the 120V to N lines as if it were a split phase service.
"Open-leg" results in "single-phasing" of your three phase motorsI've never worked with an open-leg Delta. Good to know.
Um, no. Open-leg configuration supplies all three phases ans is not the same thing as an open conductor fault."Open-leg" results in "single-phasing" of your three phase motors![]()
Most of us call what you are likely describing "open delta" not "open leg".Um, no. Open-leg configuration supplies all three phases ans is not the same thing as an open conductor fault.
