I am coming off a 240v delta 3phase panel and putting in a 3phase step up to 480v delta-delta 75kva transformer. I am having trouble figuring some things. Code says 450.3 (c) shall be protected by primary fuses. Can i use the breakers and the fuse. I thought you couldn't put fuses in series with breakers.
