Just curious how a 240V or even a 208V 1-ph GFCI operates, I know the 120v measures the current on the hot and the neutral and when there is a 5milliamp differences it opens the circuit (correct me if I am wrong) but how does a 240V GFCI work? The neutral connected to the brkr? Then is the sum of the two hot legs compared to the neutral current? How does that work with motors or losses across loads? Just curious. Thanks in advance.:-?
