SSDriver
- California
- Electrician
I have a job that is 240v open Delta with B phase grounded and I need to install a drive isolation transformer that has a wye secondary. I was curious about potentially having a grounding/bonding issue. The B phase is grounded on my primary and normally I would be bonding XO on the secondary side. I wasn't sure if I was going to have an issue due to having 2 sides of the transformer bonded. The secondary is going to a fused disconnect, then to another room to a double throw safety switch that will chose one of two drives that it will supply power to.
