DerrickM
- Billings, Montana, USA
Good evening,
I have been installing the Direct Drive Keystone LED 120/ 277V corn cob cluster lamps for the past couple of years.
I have bypassed the HID ballast in many of the outdoor bollards (3' high accent walkway lights) around campus many times as we are 277V there.
I just went on a job, started taking apart the outdoor bollards, removing the covers, bypassing the ballast, noticed the red and black, and then saw that they were wired to the 240v leads of the transformer...
Now I'm looking for a 240v LED cluster bulb but I don't think one exists, I'm pretty sure you need a neutral to make this work?
Now I'm starting to think about if I should consider changing one of the hot (240v) wires out for a white, neutral conductor back at the panel?
I certainly did not expect this and am very frustrated with myself for not checking this first.
Does anyone one have any suggestions? Would any AHJ's approve taping one of the wires white at each end knowing that it's an existing install? The conductors are number 10AWG, so they should be continuous white, but this changes everything.
The things you learn when you don't take the extra time to estimate the job properly.
Than you.
Than you.
