mstrlucky74
- NJ
Have about 10 24v electrical dampers in very close proximity to each other all be feed by 2 circuits. Each damper location also calls for manual motor starter with thermal overload toggle switch type. Note says contractor will supply transformers and electrical to install and wire. Can't locate any model in mechanical spec. Thinking something similar to this(link below) will work but not sure if there would be a transformer at each damper or one transformer could control a few dampers.
There are different VA models so that would affect wiring scenario. Just not sure which is the most common application. Thanks.
https://www.kele.com/Catalog/18 PowerSupplies/PDFs/RIB TR Series Catalog Page.pdf
