Hi...
A few years back we designed a job with about 50 unit ventilators. This past summer they started having issues with control relays in these UV's burning out. This occurred in about 1/2 of them, each at different times. The most recent one to burn out actually caught on fire. The relays have 24V ac control coils and they are fed from 120V/24V control transformers within the unit.
The UV manufacturer is claiming that there is an issue with the 120V power that feeds these units. They believe the voltage is below 120V and therefore the 24V is low, which in turn is causing the relay contacts to chatter. In other words there isn't enough voltage to energize the coil to draw the contacts in. The constant chattering is generating excessive heat unitil the relay either fails or catches on fire.
We had some power monitoring done on site and there have not been any noticable power fluctuations. In fact it was very clean. The monitoring was done on both the 480V distribution panels and 208V distribution panels for about a week. They then moved the metering further downstream and noticiced some harmonic issues.
It appears that they have added a number of computers to the building. I still don't believe this is the cause of the relays burning out.
Does anyone have any thoughts?
Thanks...
Tom
Thanks...
Tom
