minionsboy
I got a 24vac circuit with some start/stops on it that are suppose to pull in a 3phase 480v motor.
Was wondering why the voltage to ground measures at 13volts after I push and hold in the start button. Measures 24vac on one side of start button before but after once the circuit closes measures 13 volts, and so does the stop bitton since tje corcuit is closed all the way. My problem is the starter ain't pulling in. Will operate if i manually pish it in, but i have to hold in.
