24VDC grounding
wireday
New England
Master electrician
This metal box will be powered by a 24VDV .500ma wall wart transformer, Does the metal box need to be grounded? IMG_5805 (1).JPG
Thank you zbang, I admit I do not know if my feed would be isolated, It would be one wall wart feeding only this enclosure, Also what is a signal ground? are you referring to the encoder wire shield?
