hybrid theory
I have a question regarding 24VDC power supply. Is it safe or reliable to connect negative terminal of 24VDC power supply to Equipment grounding or Instrument grounding? If it is safe what should be the standard connection? Do I have to separate the grounding bus bar for negative terminal or 24VDC power supply to other grounding bus bar such as Grounding shield bus bar, Equipment or Enclosure grounding bus bar , Building ground, Instrument grounding bus bar? Standard drawing for grounding system would be helpful to me as reference. Thanks in advance.....
