Re: 25 ohms
This is the closest answer I have ever found to the 25 ohm resistance for the ground rod has to do with the old high impedence audio eq.
Go to this site for more imformation
http://www.equitech.com/articles/rep2.html
MYSTERIES EXPLAINED
Theoretically, lowering the grounding system's impedance should reduce the voltage present, but in reality, Ohm's law demonstrates that significant improvement is unobtainable. Copper building wire, for example, 12-gauge wire used in branch circuit wiring, has only about 0.l ohms resistance for every 50 feet. Larger sizes have of course, even less, but the difference is insignificant. Regardless of the grounding conductor size and length, Ohm's law, there will still be an unacceptable voltage present in the grounding system.
Furthermore, the grounding electrode (ground rod, water pipe, etc.) presents an even greater obstacle. Many have had the experience of driving one or more ground rods with huge copper wires to supplement studio grounding systems and have learned something about futility.
Commonly, if one can achieve 25 ohms or less above true earth ground, one is doing quite well. Shaving millivolts off a signal reference grid (grounding system) through grounding techniques is truly a logistical nightmare.
But what if RF filters could be made to operate more cleanly? By design, they are most efficient at doing what they are intended, suppressing stray radio frequencies from entering or exiting equipment chassis. Notice in Figure 1 that they are balanced. However, the voltage supplied to them is unbalanced. Currently, the electrical industry recognizes only one basic type of single-phase, 120-volt circuit. To ensure system safety, one of the two 120-volt supply conductors is always grounded. However, this means that one side of the RF filter has potential relative to the grounding reference; the other is neutral. Consequently, AC leaks through the capacitors unchecked directly into the grounding system.
What would happen if the AC supply was balanced? Figure 2 is an example of such a 120-volt application with an RF filter. The potential to ground on each side of the AC line is 60 Volts with each side of the circuit 180 deg. out of phase to the other. Thus, a 120-volt supply is maintained.
As a result of this configuration, trace currents flowing 180 deg. out of phase through capacitors on opposite sides of the filter null at the common chassis ground connection. Voltage formerly present in the AC grounding system is thereby eliminated. The difference is dramatic. So pronounced is the effect that conventionally accepted studio grounding methods are exposed as essentially worthless in countering low-frequency noise problems. Harassing EMI ceases. When a symmetrical AC supply is used, the noise floor of any audio or video facility is greatly reduced.
Ronald
