My question is this,when installing an equipment bonding jumper on the service supply side to bond the metal conduit to the GEC terminal the code says to use Table 250.66. The code also states the bonding jumper can be a wire,bus,screw or other suitable conductor.Why wouldnt you use a grounding bushing on the conduit with a set screw binding into the metal enclosure versus a wire sized off of the table taken to a grounding bushing on the conduit with a lug for the wire? Same question on the load side only Table 250.122 shall be used.
Seems to me this would be a lot cheaper install,but probably not better. What am I missing?
