- Windsor, CO NEC: 2023
- Hospital Master Electrician
I'm sitting here trying to explain the reason for 250.110 and 250.112's existence. Any pointers? :huh:
In general, it just seems really random.
Further, 250.112(L) in the handbook has the following commentary:
Are people really pulling out these pumps while they are energized and pumping to perform testing on them? :blink:
Any insight would be great. TIA
The requirement of 250.112(L) is intended to reduce stray
voltages and minimize shock hazard during maintenance,
when the pump is removed from the well casing and tested.
During normal operation, a ground fault to the casing of a
water pump can be a shock hazard if exposed or it could
energize a metal well casing if the pump is a submersible
type.
