I'm wondering if it is possible to use rigid metal conduit as an equipment grounding conductor for a motor in a class1 division 2 environment .
Pump guy took the outlet box off the motor and installed pump to motor because that’s how existing motor was.
Difference is new motor doesn’t have a egc coming from pottoted motor connection to j box
I’m wondering if I need to install the outlet box back on the new motor as that’s where the egc lug is located? Reroute my conduit and install a wire type egc inside the raceway from jbox to outlet box.
Picture 1 is the existing motor and pump. Had a wire type egc from motor to j box
Picture 2 is the new motor. doesn’t have a wire type egc.
