hill900505
- Texas
250.134 states non-current-carrying metal parts of the raceway/enclosure needs to be connected to an equipment grounding conductor (does not say it can be connected to a GES), I have a gutter/wireway below 3 electrical panels (nippled through), there are underground conductors coming through the gutter then getting terminated into corresponding panels. There is 4/0 ground ring encircling the equipment. Would it be code compliant to tap a ground wire from the gutter surface to the ground ring instead of having the gutter connected to an EGC coming from one of the panels?
