If I install a new Main breaker panel and use the existing breaker panel enclosure as a junction box to splice the home runs.....
....do I have to....
Bond every equipment grounding conductor inside the junction box (old panel) to the enclosure?
or
Splice the associated grounding conductors together (individually) and bond the junction box (with a seperate conductor) to the main panel?
or
Splice the associated equipment grounding conductors together (individually) and bond the largest (home run) equipment grounding conductor to the junction box enclosure?
or
choose either one?
I've always installed a (bonded) grounding bar (or used the existing one) in the junction box to splice the equipment grounds. This means that all of them are bonded together and to the metal enclosure.
I've always thought that it is required to do so...or used to be anyway, now I'm not so sure.
Any thoughts?
steve
or
or
or
choose either one?
Any thoughts?
steve
