doublecheck
- Florida
When inspecting a fixtures wiring it is noted that there are three ground wires spliced together with a common wire nut. One of the wires is to the fixture. One goes back to the main panel. And the third goes to a down line fixture controlled by the same wall switch as the fixture being inspected. In this instance the two fixtures are both lights for a bathroom. Is this considered an arrangement of grounding connections where the disconnection or removal of the fixture will interfere with or interrupt the grounding continuity? Was this a violation of NEC 1999?
