rlesperance
Does 250.52 (A) 3 require that every foundation that contains 20' or more of reinforcing rod be connected to the grounding system.
I've got a situation where a building has multiple (100 or so) individual drilled piers each containing rerod. The construction manager is claiming that every drilled pier must be considered a grounding electrode and all must be connected to the grounding system.
I don't believe this is the intent of this code section. I believe only one pier would have to be connected to the system. Where can I find a clear definition of the requirement.
